- Replies 31
- Views 955
- Created
- Last Reply
mrogers 12 posts
mario 4 posts
vern936 4 posts
dunk300zxtt 2 posts
Sympton: Car wont start. No sound from pump
Tried so far:
Checked Fuel Pump Fuse
Check car had fuel
Took off fuel pipe, cranked engine and No Fuel Delivery
Checked there was power going to fuel pump and there is
Removed CAS and turned by hand with ignition on, Injectors clicked, still no sound from Fuel Pump
Cleaned up CAS, PTU and all electrica; connectors to do woth Fuel delivery
Removed Pump and had it Tested out of the Car and it worked.
Swapped ECU no difference
Swapped Fuel Pump Relay No Diference
Swapped Fuel Pump ECU No Difference
Where do i go next?
