speedo convertor
hi need help in fitting the speedo convertor the instrution that come with it are shit and dont h elp in anyway has anybody have a idea what plug should it be wired to on the back of clock please help :cry:
well, my brain is cooked but i'll try
asuming you meen kmph to mph speedo converter "chip"
with 4 wires
red +ve
black 0volt
yellow and white??? input and output
+ and 0volt can easily be picked up from the screws on the back of the speedo top centre i think they should be labled on the circuit bourd
then you just need to cut one wire on the input conector (where the conector is depends on year of car) and conect both ends of the cut wire, one to the input and one to the output
from memory the conector is to the right as you look at the back of the speedo and the wire is one or 2 up from the bottom. butdon't take my word for it till i've checked or someone else replies
fix it to something so it doesnt ratle
[sIGPIC][/sIGPIC]
thanks for your help mate i will try that let you know how i get on i did think it was the little white plug in the moddle off the back of the clock but you are saying its the big plug on the right ?
The only advice I can give about this is don't do it.
Get a set of UK clocks and re chip the ecu.
I tried to fit one of these and it went tits up from the start. Just a bad idea in my opinion.
Goodluck with it anyway.
Darrell
i think you are right about that mate it a bit of a pain in the arse what about just puting uk clocks without the ecu being chiped ?
the uk clocks work without chipping. chipping the ecu removes "the your going too fast boing noise" and removes the speed limiter.
i removed the converter from mine as it was giving power steering problems. i'm going to just change the dial of the speedo to one that reads up to 120mph instead of 180 kmph
[sIGPIC][/sIGPIC]
yrp thats what ive done it funny you say power steering problems that what my car started doing when i fitted the converter their just shit im looking for uk clocks thanks chaps for your advice
