Electric fan that replaces viscous
Anyone got a wiring diagram ?
Those running one, is yours on permanently or comes on at certain temps ? How is it wired ?
A friend of mine has just had one put in his S14, i'll try and get the diagram from him for you mate.
top man, I think I need a thermostat or something. At the moment I'm just plugging it into a live relay, but that way it's on permanently even which the ignition off :(.
hey there,
i have a Zcentre electric cooling fan and it is wired into the fuse box passanger side at the front of the engine bay.
comes on at a set temp. (set by me).
can post some pics of the wiring diagram i got from the Zcentre if you like.
alan.
hey there,
alan.
That would be ace mate.
I think I'm missing the temp sensor that it must use.
Any pics or info would be great.
hey smw1
have been looking all day and i cannot find the drawing for wiring in the electric fan. took some pics to show you if it helps.
get in touch with luke at the Z centre, am sure he will send you his wiring diagram for the electric fan instalation.
cheers
alan
thanks Alan.
I'll browse the net a little and then contact Luke if I can't find what I need.
Just on a side note my fan came with an electric switch witch you can fit so it comes on as a certain temp and also has a manual override.
However it looks like something from an old boiler and has a copper rod coming from it which the sensor is mounted in and I assume a thermostat. You can turn the knob on top to make it come on at lower or higher temps. I'm thinking I will maybe just buy another switch, a more upto date one so to speak.
  • 9 months later...
does it look somethin like this??? if so, thats the thermo switch...its what turns the fan on and off at the set temperature.
......................9 months later!!!!...................
nice one:tongue:
......................9 months later!!!!...................:rofl::rofl:
nice one:tongue:
nice one:tongue:
oops...haha i didnt even look at the date!!! :headvswal :rofl:
nice one:tongue:
Thats a bit like my kenlowe controller, i wouldnt recomend them there (s**t) imo only!
Kenlow have been making these kits for many years and are very reliable.
if fitted and set up correctly there very good.
D
Never had a problem with mine until the day the connector droped off the battery then all hell broke loose :rofl:
Apart from that, bombproof!
Hi mate
My electric fan is wired up to the perm live via a relay. There is a temp sensitive switch on the rubber water pipe connector which switches it on and off. HTH
looks like a 1920's sex aid.....
