Oil in the plenum and the pipes....
Does this mean one of the turbos is bust? smoke pours out the engine and the exhaust when it is runnning, had a look and theres loads of oil burning in the pipes, so there is definatley a leak! but could it be a burst turbo?
also is there an easier way to get the turbos off without stripping out the entire engine?:cry:
It sounds like a turbo seal(s) gone but also could be a piston ring / damaged piston.Sadly both failures requires the engine to be removed from the car to rectify. The turbos can be refurbished for between ยฃ200 to ยฃ400 each.To find out if you have a piston related problem, do a compression test.
