Injector & Coil Pack conectors needed
As above, where is the best place to get these from? Is there another make/model of car that you can use?
Thanks....
Thanks for that, any idea on shipping costs? And do they "adjust" the value for less import tax etc?
I assume their coil connectors do come with wires as per the image? Because the words say you dont need to splice them.
they come as u see them in the pic, i bought a set of 6 of each..... they will reduce value if you tell them. Add items to cart to calculate shipping costs. Wont be much, but well worth replacing the 15 year old wires i recon.
It may be worth buying an extra injector connector to use incase the front water temp sensor or any other connector which may be broken as they are the same type connector.
