Hello all been having this problem with the zeds idle, on tick over the revs are up and down like a lumpy cam nearly stalling doesent jump up past 1000rpm.
But when you stick it in drive I accelerate normally and the engine holds back so give it more gas but still the same? then the turbos start doing all the work, It gets worse if engines cold then its a nightmare! smells of fuel too!
I know the yellow connector on the metal water pipe, the wires are a blueish colour so need to chop them and rewire, could this be the main problem for idle? or maybe MAF sensor??
cheers in advance!
