Hi all, put my box back on yesterday, all seemed to be ok, went on relatively easy. Come to fit starter motor, clutch slave cylinder etc today and noticed that the clutch operating arm (not sure what the technical term is) was at a bit of an odd angle - it appears slightly twisted. Not sure how this can happen if the shafts are all lined up correctly and the gearbox is straight (I'm pretty sure it is). There is no play at all in the clutch arm when the box is tightened up - is this correct?
Advice appreciated. This is doing my nut in!!
RobH
