steering wheel
sure it's just a case or remove the centre (one screw underneath and it should pull off), then undo the bolt (something like a 19mm bolt) and pull the wheel off.
Vijay
as above but leave the nut on as you pull 1. so you dont hit yourself in the face and 2. the is a block connector for the cruise control and you could break it
