Are UK and US pcv hoses the same?
I have heard they don't have the wire brush inside on the us one but are there any other differences?
I replaced mine last weekend. I am in Australia with a Jap spec 2+2 TT. Bought the hose and valves from Concept Z Performance in USA. Great supplier, cheap and quick.
The hoses are not a lot of fun to replace, especially the rear one. The best advise I received was "don't try and get the old one off in one piece". Get yourself a good set of long nosed pliers and tear the old one off in bits, it'll be really brittle. The new one slides on like a pri*k in a shirt sleeve - easy. Good luck
Tony from Oz
There is some question over the wire brush and metal disc, the wire brush seems to be no more on the US ones?
There is some question over the wrie brush and metal disc, the wire brush seems to be no more on the US ones?
in other words they are the same :D
:confused:
The UK ones used to have a wire brush and a metal disc in them, the us ones now only seem to have a metal disc!
not sure then matey, if they fit then they should be ok, never had mine off yet so i dont know what they look like but mine will be comin soon so i'll let you know!!!
:confused:
No so. The ones I bought from the States had the disc and the wire brush.
Tony from Oz
yep, I have just fitted new ones to mine, bought them from Courtesy in the US, they had discs and wire brushes.
If someone can check their pcv hoses as I have a few out of their packets, the driver side hose just has the metal disc in.
The passenger side hose has the wire brush and metal disc?
I presume both the hoses connected to the cam covers are the same, with the metal disc in, no wire brush?
