Water pump / viscous fan advice
Can a worn/loose viscous fan/assembly cause water pump bearings to collapse? opinions needed thanks in advance
the main reason would be the belts were too tight tbh but if the bolts were left loose then yes as it wouldnt run true !
The fan and the viscous coupling are quite a big lump of metal, and if that was left loose or not sat down properly on the pump mounting face, yes it would knock the pump bearings out.
