Thought I'd share these with you ..... you never know when they will come in handy :)
1. IF YOU'RE CHOKING ON AN ICE CUBE, SIMPLY POUR A CUP OF BOILING WATER DOWN YOUR THROAT. PRESTO! THE BLOCKAGE WILL INSTANTLY REMOVE ITSELF.
2. AVOID CUTTING YOURSELF WHEN SLICING VEGETABLES BY GETTING SOMEONE ELSE TO HOLD THE VEGETABLES WHILE YOU CHOP.
3. AVOID ARGUMENTS WITH THE FEMALES ABOUT LIFTING THE TOILET SEAT - USE THE SINK.
4. FOR HIGH BLOOD PRESSURE SUFFERERS ~ SIMPLY CUT YOURSELF AND BLEED FOR A FEW MINUTES, THUS REDUCING THE PRESSURE ON YOUR VEINS. REMEMBER TO USE A TIMER.
5. A MOUSE TRAP PLACED ON TOP OF YOUR ALARM CLOCK WILL PREVENT YOU FROM ROLLING OVER AND GOING BACK TO SLEEP AFTER YOU HIT THE SNOOZE BUTTON.
6. IF YOU HAVE A BAD COUGH, TAKE A LARGE DOSE OF LAXATIVES. THEN YOU'LL BE AFRAID TO COUGH.
7. YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
8. REMEMBER - EVERYONE SEEMS NORMAL UNTIL YOU GET TO KNOW THEM.
9. IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM.
good advice that, i'll use it every day :D
Thought there were going to be some cures for aches and pains to help the missus through her cold, Ive got my own remidies but she dosent want to try them.:(
headache: Sook on this it will take your mind of it.
sore throat: Sook on this and then you can gargle.
tickly cough: Sook on this, forget the gargling just swallow.
general aches and pains: back to sook on this it will take your mind of it. followed by spraying of special ointment on affected area.
toothache: forget it you might grind your teeth, heres some asprin and phone the dentist.
