Pas power window.
Iv'e been searching the forum for reasons why my passenger window won't work, and came accross a few posts saying there is a black box under the pas door panel under the handle (same as on driver door) which controls just the passanger side window, well ive been out and half removed the panel as cant remove the whole thing beacause the window won't go down :headvswaland there is no box, so i tried a new pas and driver window switch and a new control box on drivers door but still the window does'nt work, can anyone spread any light on this as i don't know where to look next......thanks jay
You sure the its not just the disable switch on the drivers side? lol
It's deffo not the disable switch lol. but i swear iv'e tried everything i know of, and the spare black box in the driver door i tried has had the dry solder joint repair done a few months ago so i know thats a good one...
You checked the motor by applying power direct?
not yet, will that be the small white plug with yellow and blue wire in it?
there is no black box on the pass side. the drivers side controls both.
Have you wired a direct feed to the motor???
