quick Q - oil change
guys jus changing the engine oil, online manual says 3ltrs refill....is that enough??
my old mans motor took 6ltrs
jaz
Hello Jaz,
Ur best bet is to do a quick search. I think they're all different depending on auto/manual jap/uk - I think.......
Vijay
bout 4 litres went into ours, think it might be a little too much though, the oil pressure is quite high when cold
cheers vij, clark..... my dipsticks showing full at 3.5ltrs, must be right smile.gif
3.5litres exactly.
Doesnt seem much but thats what it is.
Leigh
When you drain the oil from a Z, does it all come out ?
Clarkey oil pressure will always/should be high from cold as it's thicker and obviously when it gets nice and hot it's thinner. wink.gif
Dave some people can get the filter and sump nut off without having to jack the car up. I raise the car to get the gubbins off then drop it back down and have a cuppa and leave for about 30 minutes to get 99.9 percent out!
Then I jack it up from the passenger side for a few minutes to get that .1 percent out of the sump! wink.gif
As advised by Le Big Mac!
[This message has been edited by Timmy_Turbo (edited 14-08-2002).]
