fitting carbon fibre air ducts
reading a thread on the z related discussion section about buying loads of parts and having them lying around ..you know the carbon fibre air ducts you can get to replace the fog lamps...does anyone know how to fit them ..i mean there are no holes to screw them in with and do you have to remove the front facia and the struts behind the fog lamps :confused:
cheers
Maz
you can try and bond them to the bumper but, the ducts might not be a perfect fit. or you can self tap them as there is a lip to hide the srews, or sauce yourself some sprung "U" clips to hold them in.
pending on the size of ducting you use will depend on weather the fog light bracket will have to be cut, or just leave the bracket off completey
can the fog light bracket be removed without removing the front fascia ?
cheers topless...but I assume as silverbullet said, to remove the fog light bar completely you have to remove the front facia , which isn´t a problem really as I had planned on taking it off to remove the carbon canister ..so thought i´d ask and see if then would be a good time to fit the ducts.
