thick sticky sustance
Can anyone tell me what is drippin from under the front corner at the drivers side of me z its a clear thickish gloop,theres not a lot but it drips quite regularly
I was thinkin its maybe ectoplasm maybe theres a spook under ma bonnet
:eek:
I think the original front tension rod bushes are filled with silicon or something similar, so could be your bushes are fooked..... other than that your motors haunted :)
yep leaking bush , have you noticed it knocking when going over bumps ? if not you soon will :)
you sure youve not popped a CV joint. sounds like CV grease
No cv joints at the front of a 300zx :D
There is on the rear tho on the driveshafts :)
Its defo a leaky tension rod bush get them buggers changed....
I think i should start buying used rods and fitting new bushings in there and selling them. Id make a fortune.
Seems to me like every other car on here has a leaking bush.
well if your near me and you need one replacing il fit both for 30 quid ;) as long as you supply them ;)
what he said:D
the silicon that leaks from the bush almost looks like a melted sugary sweet consistency lol
I usually start leaking a sticky substance when I look at my zed mate, nothing to worry about, just carry some tissues around with you. :nelson:
could you have cracked the screen wash bottle? mine had a clear goo in it a few months ago try the washers if you get a slime come out or nothing at all it could be that. if not ive got a ghostbusters dvd u can borrow lol
Thank f**K i hate ghosts
Suppose i cant complain i've had 4 months trouble free motorin can anyone recommend a replacement
Perhaps now would be a good time to start replacing all the bushes ive seen a compete set of bushings for the z from the states anyone bought these :)
Spot on... change them all.....
either energy/whiteline/driftworks bushings
What suspension you got on there? standard?
Im not sure jimmy ill need to check this weekend i think its standard
Any idea what the ride height should be for standard mate
Not a clue..... see how many fingers you can get under the rear arch before touching the tyre... when mine was dropped 30 mm i could get 2 fingers under there. so id say about 3 sausages?
Dont have any sausages will a kitkat do :D
I didnt think they had a CV on the rear either just 1 prop into a diff then out to 2 halfshafts which join onto the rear hub assembly, didnt think the zeds fractional rear steering would require a conventional cv joint???
its still a cv joint or whatever you wanna call it with a gaitor boot on each end of the drive shafts so if the rubber splits and all the grease leaks out you can say goodbye drive shaft.
  • 1 year later...
my gaitor boot on the wheel side has split and lost some of the grease so is it possible to replace the boot with a new one without taking the driveshaft apart.
