Oil cooler
Hi All,
Hope some of you can help?
Ive heard its advisable to upgrade the oil cooler on the zed when you start modding the engine to a higher spec.
What size cooler would be advised?
Ive got a 13 row mocal but not sure if it will be good enough over stock for my import tt manual.
I'd recommend 19row. Its what the UK had fitted as standard and what Nismo offered as a performance upgrade.
..and yes its is advisable, with the puny stock oil cooler the oil can getS too hot that it thins out and wont go through the valve to the oil cooler which then rockets the temps even higher. If after a hard run you touch the stock oil cooler and find it cold then thats what is happening !
