Hi I'm new to the 300ZX world (previously mostly V8's and a Porche Carrera 911, it now feels good to kicks the V8's arses...),I live in Australia but it seems you guys are more into the 300zx scene than we are here. I saw a stage 3 chip on ebay here in Oz for a claimed 400rwhp made by Marobi ????
To me this seems virtually imposible with the following details :
With this chip Your 300zx will put out a staggering 400 BHP at the wheels.
You will need a free flow air filter.
A good free flowing exhaust.
440cc injectors........but this chip will work with standard 370cc injectors as long as you don't go mad with the boost,stay at around 14psi boost.......or just tweak your fuel pressure regulator for a bit more fuel.
This chip is mapped to adjust fueling and timing for up to 17 psi boost.
REMEMBER THE STOCK TURBO IS ONLY GOOD FOR 15 PSI TOPS.BUT THIS IS NOT THE LIMIT OF THE CHIP
Rev limiter is raised,and speed limiter is removed on imports.
Engine timing will want to be set at 15 degrees EXACTLY.
And of course the higher the octane rating petrol you use, the more performance.
As they say if it sounds too good to be true then it probably is.......
ALSO I have heard that if you insert boost valves it too will increase your power if so what size should the hole be and does it have to be in conjunction with a new ECU chip.
My boost is currently running at about 14 PSI. I havent played around with the setting but it doesnt seem to be pinging, but I do run out of steam at about 6000rpm (it is a Jap import).
Any help would certainly be appreciated.
