Best mod i've done so far
My zed tt has felt 'loose' and floaty for a while now, i put new upper arms on, new tension rod bushes, shocks,arms,bushes,balljoints(- what a toss job that is!)
At each stage it felt better,but still loose.
I finally put new whiteline adjustable anti roll bar links on the back.Strewth.
Bloody thing is transformed :) doesn't hop,skip,stays flat on roundabouts, WHY didn't i do this first.
Brilliant :hyper:
£25? 20 minutes :wack:
Just do it, if you are running about on 15 year old links!
yeah i uprated to energy link bushing and it felt better but the bottom roll bar buhings are the wrong size so im guna buy a uk roll bar soon :D
or maybe even the whiteline kit :)
where from and how?? You take any piccies during the job? Yes...I'm a noob...:wack:
if ya get the bits pop round and il show you how to fit them very easy.
They were from zcentre, i just cut the old ones off + bolted new ones in.( you have to measure between bushes on old one+ set new ones the same.
If you have a look at them, you will see what i mean.
Echellente! Sounds like another good idea batman! One for the future though I think as got a lot on at the moment and not many spare weekends but cheers for the offer!
Thats for the tip bud! Will keep in mind when I get round to doing this!!:)
Will be a good idea to buy the bottom bushings aswell as they may be fooked but be sure to get the right size as uk and import are different sizes... i found out the hard way :(
Yep, fubbared ARB drop links are very typical. Well worth changing wether or not you change the ARB's too.
I changed my TT JDM ARB to a UK ARB, new bushes and drop links and the difference with the rear is amazing, no hopping around or anything
