- Replies 33
- Views 3.5k
- Created
- Last Reply
vern936 13 posts
(Z)Master 5 posts
Corvetteman 4 posts
zx-eyes 2 posts
Just to let everyone know, I am now the proud owner of a 1990 300zx TT SWB T-Top Black Jap Import (I'll get some photos uploaded when it's clean)...BUT I've got a bit of a problem with the car blowing PTUs at the moment and I could do with a little help working out what the problem is. I've checked the PTU for continuity and it's dead so I know I definately need a working PTU but would like to find and fix the problem to prevent it from blowing another one. Does anyone have a cheap working S1 PTU I can buy to test the car with? (I know it'll need a S2 eventually but don't want to fork out the extra money in case it blows it again)
The PTU is getting it's 12 volt feed on all 6 pins on the input connector and the earth has little resistance between the earth pin and the battery -ve post but from the connector that connects to the output side of the PTU there is a 4.4 volt feed on all 6 pins :confused:
It looks like I'm going to have to strip the loom back and find the short/breaking down component that is backfeeding through the loom but I found it a unusual that if the 4.4 volt feed is a problem it would be on all 6 pins so I thought I'd better check on here first.
By the way - I know that the usual problem with S1 PTUs is that a dry/disconnected joint inside the unit but I have opened one of the car's previous PTUs and checked the joints and they're all OK but there's still no continuity through that unit either so it looks like the actual transistor bit is fried. My first thought was to check the alternator is charging correctly i.e. not over 14 volts but now it has blown the current PTU I obviously can't check this.
Regards,
James
