Boost controllers with high boost button?
Hi,
I spend most of my time poodling around in the zed and like to turn the boost on high when I fancy a blast!
My profec eo1 has to go through a menu and then select high boost and go from there, I know there is a high boost button availabel for this but I fancy a change!
So what other boost controllers out there have a button just to select high boost?
my profecB 2 has hi lo and off all at the push off a button. Is residing at off for the time being due to cash lash out on engine
On the HKS EVC V there are two volume knobs A and B so you can set the desired boost on each one (i.e high and very high :P) and switch between them at a push of a button.
To be truthful living in London the opportunity for enthusiastic driving is limited so it is pointless running decent boost all the time.
Mark with the Profec E-01 I thought you just press the shift button on the remote to go into High boost mode. I've not used mine yet, but thats what the Manual says
Just tried the shift button trick, and it puts me into overboost mode which I have been warned against using.
Just keep it in high boost and be easey on the pedal when you want to drive steady. No need to switch.
he just wants a big button to press :tongue:
Not the same, would like to have two modes, with less stress on the turbos/engine/drivetrain.
And yes Alex I want a big button to press:hyper:
I have the Greddy Profec 2 and has a nice shiney button which changes you from Low - High Boots plus a Twisty nob to change settings! I figured it all out without reading the manual so its easy to work too :)
Always cool to tell the ladies press that button and then WEEEEEEE!!! :)
I know it's old but...
The blitz sbc-id has a program range.
So you can set a number of channels up.
IIRC I had channel 1 set at 10 psi, channel 2 at 14psi and channel 3 at 16psi.
Channels can be changed at the push of a button, rather than a push of a sequence of buttons.
Top Tip:
If you only press the far right pedal half way down the boost stays low.
Press it all the way to the floor for full boost ;)
:rofl:
Top Tip:
:rofl:
Nice Avatar Chris. FPMSL :rofl:
Top Tip:
:rofl:
Dam that is where I have been going wrong all these years:eek: :D
