http://www.zcentre.co.uk/shop/product_info.php?cPath=21_43_69&products_id=342&osCsid=ceb454a70e544953814535a204e45b1c
Has anybody used these gauge pods from z centre, just wanted to know how hard it would be to fit it without having to remove the dash as it says theres cutting involved.....
Thinking of getting some prosport gauges as theyre the closest to defi without the extreme costs.....but i want the centre dash pods which i cant find
Any help will be great
Fas
theres not much to fitting it at all. as it says, comes with template. only for 52mm guages though. saw this in the flesh before it was put on the website. if it would have accomodated the defi bf 60mm, i would have had one myself.
defi now do 52mm racer series gauges that do not require the link they just plumb straight in like normal gauges so im thinking of ordering this and buying these gauges:)
look nice but they need you to cut into the dash to fit the gauges:shock:
Thats not bad, although :eek: at the poor fitting in the pics..you can see the glue residue all around it :rolleyes:
just for the record. i was present when these pics were taken. the item was not fastened, or glued to the dash. the bit on the right is where the dash was cut out a little too much & was only used for test purposes. was not even wiped down. i hope this helps.
as for the size. yes, defi do 52mm guages, but i want the bf range.
cutting the hole to big isn't any better than leaving glue residue, shame Luke used those pics. The product itself looks ok though.
yes, the product looks & matches the dash very well. think the pics were done in a bit of a rush, but it gives you the general idea. :)
So is that a yes or a no for this being a good product, how hard would it be to cut the dash with the dash not being removed?
Fas
Fas
it would be very easy to do, no need to remove dash at all.
thanks alot mate.........will defianetly be an option now as iv badly wanted some gauges in the car..... as the current greddy set up doesint make me happy and the oil pressure gauge has started to play up
Any more information from anyone else would be great
Fas
have a look in the groupbuy section, theres 1 going on now for some neat lookin gauges
He has already ;) :D
LOL...... when i want something i look at everything, i try not to miss anything out
Fas
i'll just shut up now :o:rofl:
yeah. and dont forget ya coat :slap::rofl:
cheers Paul :rofl: i'm going :cry: i know when i'm not wanted:cry::cry::rofl:
Fas
I have Defi BF gauges on mine which of course are 60mm.
The problem i had was i have 4 of them.So i mounted 3 on the dash and on my A pillar i have the Defi boost gauge and 2x 52mm AEM Ueago AF gauges which Luke kindly made up for me.
So you've actualy got the dash pod im talking about, how hard was it to do and what is the quality like..... any decent pictures would be much appreciated mate
Fas
Release the hounds :rofl:
Only kidding mate
No you've said it now fook the lot of ya :rofl:
only jokin, i don't know what i'd do without you lot :)
Fas
No mate the pod wont take 60mm gauges so i had to use the mounts supplied with the gauges.
