Autobox
Hi guys, just a quick question, is a autobox from a uk spec tt compatible with a j spec tt
would i need to change anything wiring/ecu or is it a straight swap ??
thanks
I had a straight swap from J spec to UK spec TT with no issues and all the same connectors so the converse should also be true, I think!
The different ECUs cover the different controls such as sport hold and whatever
i just put a j spec in my UK car, it's all the same
Did you change/ swap any other components or just the box ??
