grrrrrr damn RS focus
what the hell are in these. i was on the A12 at the weekend and a Focus RS pulls in front on me. we started racing but he was basically leaving me behind. i started to catch up but restriction kicked in and.... bah he got away.
i know my car is heavier and i have limit restriction and auto goign into HIS favour...... but jesus what are those things....... i still love my zed but would a manual of made the difference or would i have to mess about with the car to beat it. i want to leave my zed stock and i can admit my car isnt that fast these days compared to all the lightweight high revving cars out there.
guess ill just stick to driving it slow and not bother letting anyone challenge me ^^..... don't really want to die anyway!
  • Replies 34
  • Views 1.1k
May not have been a stock focus RS, i know stock ones arnt super quick, but the brakes on them are something else.
theyre a tad slower to 60 than the escort rs cosworth arent they and the cossie is about 5.8 (according to max power :p )
should a stock 300 beat a stock rs? maybe not 0-60 but say.... getting to 100 or so. or is the weight and the auto not going to help me out at all? i would like a manual next but my mrs has her heart set on gettin the 350z in the next few years as she wants it so damn much. i know according to top gear the older is faster but she isnt bothered on speed... she just likes the 350z looks!
although i will be getting manual next wether its the 300 or the 350
Stock TT definatly quicker than a stock Focus RS. I had a play with one about a year back on motorway and I was much quicker, he would'nt give up, and I kept leaving him over and over.
Stock TT is quicker at all speeds, 0-60, mid range and top end
ok then. by the way im not really into modding but what could i do to make the car quicker without causing toooo much stress. i would of liked to keep the normal exhaust as i prefer it however i know people are going to say thats a must for more power....... i just dont like loud exhaust noises
as you can see im not a moding person and i have no clue on what these mods do or how they work :-(. i would like the car to be as standard as pos
intake, chip, boost increase to about 14psi, preferably exhaust too. as long as the motor is in good nick. you can use mig welding tips (nicknamed boost jets) to increase boost for a few pennies or install a propor electronic boost controller for a couple of hundred if you want the job done properly and the control over boost.
First thing to do is make sure the car is running properly. You dont want to play around with increasing power until you know everything is working correctly first.
There are many factors that can affect power - Boost leaks, safety mode, Running too rich from poor o2 sensors or Temp sensors, Incorrect timing, Clogged Fuel dampners/regulators...etc
Fixing many of the above will also have other benefits such as improved fuel economy.
Best bet is to drop the car off at a specialist for a health check.
ok i will do that once the pug is sold..... i will look into these mods. although is there a way to get a good exhaust that makes as little noise a possible. 1. im not a huge fan of loud exhausts and 2. My mrs loves the car as it is and will not drive it with a loud exhaust.
As Legrath says the Z is quicker altogether, but the handling on the RS Focus is superb, the Focus would have you round the twisty's...
thankyou for clearing that up mate ^^ although it makes me think why they didnt do that in the first place?
It's a 2.5L Volvo Turbo engine and some very nice new suspension so I would think a stock Z would be about even in a straight line with the extra weight but on the twisty bits the Focus will handle much better.
Focus ST: 2.5-litre Duratec five-cylinder 20-valve engine, turbocharged to develop 222bhp at 6,100rpm and 236lb-ft of torque at 1,600rpm
so that means it wasnt stock? wll whatever he had done the little bugger flew off
Focus ST and the Older RS are different engines
Engine Data
Engine type - 2.0-litre, 16V Duratec RS
Transmission
Gearbox - 5-speed, revised gear ratios, Quaife automatic torque biasing differential. Heavy duty AP Racing Clutch.
Suspension and Body
Front - Redesigned MacPherson strut suspension with uprated offset coil springs/Sachs racing dampers, 65mm increased track width.
Rear - Independent, Control Blade multi-link suspension increased in stiffness, Sachs racing monotube dampers with internal rebound spring, uprated springs, increased track width.
Interior
Sparco race-style leather/Alcantara trimmed bucket seats in black/blue. Black/blue leather steering wheel with stitched-in oversteer indicator. Sparco aluminium handbrake, gear knob, pedals.
Performance
Max speed 144 mph
0-60 mph 6.4 secs
0-100 kph 6.7 secs
Fuel consumption
Combined
27.9 mpg
Emissions
CO2 – combined mode (g/km) 237
More Focus RS Engine Spec
Engine Data
Displacement – cc 1,988 Bore, mm 84.8 Stroke, mm 88.0
Fuel type, grade Unleaded petrol
Max power ISO kW/PS 158 / 215 (212 bhp) At engine speed (rev/min) 5,500 Torque ISO Nm 310 (229 lb-ft) At engine speed (rpm) 3,500
Construction
Cylinders - Four in-line, with forged pistons and connecting rods
Cylinder head - Cast aluminium alloy
Cylinder block - Cast iron equipped with improved oil system
Valve gear - DOHC, modified valve seats, sodium-filled exhaust valves
Camshaft - drive Belt
Engine management - Ford EEC-V
Pistons - Forged/oil-cooled by oil-spray nozzles, fed by the main oil gallery
Induction- Garrett stainless steel, water-cooled turbocharger, over 1-bar maximum boost, water-cooled intercooler, new throttle body with improved sealing, redesigned air induction system
Exhaust System - Large bore stainless exhaust system
Injection - Sequential electronic fuel injection (SEFI), High flow rate injectors
Fuel System - 55 litre fuel tank with internal uprated fuel pump, Revised fuel pressure regulator valve
Ignition - Ford electronic distributorless
Emission controls - Closed-loop; 3-way catalytic converter with close-coupled catalyst
Cooling - Increased capacity water pump, high efficiency oil cooler, water-cooled intercooler, uprated engine cooling fans, turbo heat shielding
Oh yeah I thought I read Focus ST not RS.
Should have beaten that easy on the straights.
yeah but like mentioned to me earlier that must of been modded because i wouldnt of caught up with that until about 130-40 ish. my limit kicked in before cathcing up
or your car is'nt running at 100%.
yeah that could be possible........... seems fine and doesnt hesitate. went in for a check over when i had my cambelt changed and he couldnt see anything wrong. apart from pulleys worn and needing replacing
simple bluefin remap, exhaust and a few other mods can see the RS to 300 bhp which would give a near stock 300zx a very good run for its money ;)
Have you checked you aren't stuck in safety boost?
There's a lot of Z's with minor faults causing them to keep the boost down and if you don't know any better the car will seem fine.
From reading your other thread, seems to me like you do wanna go faster, so stop pretending and get booked in for a rebuild:) Then you will Crush anything that challenges you ......
