Whats the diffrence between a turbo ecu and a N/A ecu any help would be apprieciated cheers chris
Different fuel and ignition maps, different size injectors, outputs for boost solenoids....
Aside from the maps, which are on the chip (eg alterable), there is probably only one difference and that will vary depending on the year of the ECU, and it's the boost solenoid circuitry. If you have an aftermarket boost controller then these are not used anyway. So, .... in theory .... you can put an NA ECU into a TT car if you have an aftermarket boost controller.
Stock boost solenoids could be wired up to be permantley operating anyway. It IS feasible but probably not worth the effort
