venom injectors
Bought some Venom injectors of Ebay. (I know... :smw: ) I have delivered them for testing. There was no documentation with the injectors i got...The company that are testing them need to know how much they are supposed to delivery under a set pressure in order to see if they deliver what they are supposed too...
Hope this makes sense to someone. not the best explenation i guess...
PM Jimmer mate he should know as he has them fitted to his motor and also put them in mine
Test a 2.5 bar fuel pressure.http://www.sxoc.co.uk/vbb/showthread.php?t=340049
buy a aem gauge afr and you will know if ur safe!!
OK, Out with the Venom injectors
Thought I would go for either the Nismo 740cc or PE 850cc.
I see that there are two kit versions from Z1 motorsport. One with the 300Degree rails and one with machine lower plenum. What is recomended and best? Will PE 850cc use more fuel than the nismo 740CC or nismo 555cc?
As far as I'm aware a lot of fuel injectors failed (nismo too) in America because they put ethanol in the petrol. Alcohol does not do regular fuel systems any good at all :(.
