Best route for amp and speaker wiring
why im buying my sound system just thinking which is the best way to wire the car, eg enterence from battery into car, amp location, wires to doors etc
regards andy
im sure there was a post put about by vijay about running the power cable. Might be worth while to do a search for it?
From experience, run the power cables on one side of the car and speaker cables down the other - minimizes interference.
Dan
this is the route I took when I did mine. Down the side off the battery and there is a little plastic cover with a hole notched into it. Into the space behind the arch liner. There's a huge rubber grommet in the hole in the pic, make a hole in it - through there and out into the cabin. Silicone it back up.
I did exactly the same thing, the wire comes out by the ecu so nice and easy to get to just pull up the carpet and wooden cover then away you go!
same for me, nice and easy, also as already mentioned, you do run the power cables separate to the rca and speaker cables, otherwise you get engine noise through your speakers and clicks when your indicators are on and amped up, its not nice, Good luck with the install fella ;)
