is it easy to fit a manual boost control or has anyone got any suggestions on upping my boost, as its running at 7psi. :confused:
If its 7psi then its in safety boost - more than likely an ECU error code of 34, knock sensor
Sounds like the car needs a good looking at
think it does. but i think its worth it. taken me a long time to get this car. got a lot of plans for it.
Thats why you need to drive to S yorks ;)
Don't up the boost if the car has problems, you're only asking to make things worse
