trigger wheel??
Hi everyone,
What is a trigger wheel ive been told to fit one while rebuilding my engine?
36-1 apprently :confused:
Who told you that? A ford tuner? lol
No need for a trigger wheel, the Z has the CAS for that purpose :)
If it's for aftermarket ECu then you might have to fit one as some don't recognise the nissan pattern. Also the nissan one uses 2 inputs so that might be an issue if you need them for something else.
For neatness on mine I made a new trigger disk for the CAS with a 36-1 pattern then just used the inner sensor witha pull-up resistor as the input. Better than a hall effect as it's a 12v signal so much less prone to interference.
Pic below showing new one vs nissan original.
