injectors , cam gears
Hi all,
My engine is nearly complete except turbos & injectors.
My question is can i buy bigger drop in replacements than nismo 555's for my 1991 import tt.
Also where can i find a cheap set of adjustable cam gears?
Thanx
Dan
Injector wise not really, however if you fit new 300 degree fuel rails as on my site, you can fit 740's and 850's if you like, the bigger flow injectors are also cheaper to buy than the early 555's and if you go with the new fuel rails, you'll eliminate the problem pre 94 zeds had of lack of fuel to no.6 piston, (usually only found when chasing bigger power)
As for cam gears, deffo nowt cheap am aware of, only well known brands such as Jun and around 250 quid a pair.
smithy
why do you want the cam gears? you'll loose VTC
