I have a engine problem I could use some advice for.
The engine will not rev above 2500 rpm.
At a standstill if I hold the throttle at 2500rpm the engine appears to rev itself between 2000 and 2500 rpm, very rythmically like hitting a rev limiter as it chops at 2.5k.
In fwd motion as you hit 2.5k the car judders violently.
Over the last few months the car has had a similar problem, it was reluctant to accelerate under light throttle, it would stutter etc but would get through it and rev out fine. Sometimes though you could run it without a problem.
I have had issues with the two water temp sensors at the front but am pretty certain I have a good connection there at present as the tickover is fine.I did find a broken wire here on the single spade plug and a loose connection on the double spade just before this 2.5k limit problem started. Could it be that the ECU needs to be reset after coping with dodgy wiring problems?
Morning all,
Any ideas please?
Cheers Rob.
