protoj · Tuesday at 18:48 1 day
Hi, does anyone know how to uninstall Apexi controllers (fuel/air & boost) from a zed, a turbo timer, and Greddy temperature and boost gauges? Is this easy, or a pain in the a**e?
Cheers.
