In memory of Mandy
vibrations when setting off
hi everyone, i finally have my car back on the road! wooohoooo :dance:
i recently had to replace the passenger side drive shaft and now i get a light 'shudder' when setting off... vibration kinda feeling....
i am not sure what it can be? but it never used to be like that and i guess its not good?
wondered if any1 has experienced this and can recommend anything to make it disappear?
thanks in advance.
is it manual? cos it could be clutch judder!!!
My BMW does this, i was told it is the rubber prop bush that is slightly out of round when its cold, it normally goes when the car is warm though, i was told that to correct it specialist autobox centres can actually balance them...
how true all this is i am unsure as i was only told this by a mehanic... Hope it helps anyway
Could be prop bearing although you can usually hear a plusing, vibrating sound at about 50.
Ivan
its just on set of for like 1-2 seconds.... not whilsts driving... just set off. :confused:
