Revs down before it goes up
why is it when i blip the throttle at idle it first goes slighty lower in revs then up the revs like a slight hesitation? really annoying. im sure this has something to do with my dodgy idle at cold starts.
Mine did the same, I changed the ECU temp sensor and it seems to have cured it. Think it only cost about ยฃ10.
Hesitation. Lots of possible causes - Dirty throttle valves, throttle valves not equally aligned, Vacumn leak, incorrect timing, poor fueling (temp sender, fuel pressure regulator) ...etc
ahh annoying, i just wanna it fixed noooww ahhhh.
well temp sensor is new. i remember cleaning throttle intakes just a while back.
i adjusted the throttle valves so they are the same on each side, timimg is bang on 15,
tps is correct. hmmmmm whats left?
make a boost leak detector ;)
yeah im still to do that:)
the odd pipe keeps blowing off but i always spot them and put them back on.
