protoj · 7 hours ago 7 hr
I use to own a Twin Turbo and have some brand spanking new still in the boxes VERDE 5's 17" 5 spoke Chrome wheels which I never put on my car. If anyone is interested in them please contact me 07932 042 060
Konrad
