Hicas arms.
I've had the hicas disabled but do i need to keep the hicas arm rod thingys which connect upto the back of the rear wheels?
How have you dissabled it because with a hicas lock bar all it does is replace the rear rack you still need to re fit the rear hicas arms .And if there is play in the inner joints or the outer hub joint you will still get movement at the rear.
