Coolant Bottle Re-location
Hi guy's..
I have a new set of wheels, that have pretty extreme offsets on the front, and the front nearside wheel rubs the coolant bottle on full lock.
Has anyone ever re-located their coolant bottle?.. If so, how, and where to?
Any advice appreciated.. Apart from.. "get another set of wheels" lol
If you mean the expantion tank.Give Luke at the zed center a ring as he does a kit. http://www.zcenter.co.uk
Yes, that is what I mean Vinz.. I didn't know that the zcentre did anything for this issue.. Thanks very much mate.. Appreciated ;)
You can move the expantion tank to behind the wheel arch instead of in front and bring the filler cap kneck up through the hole in the inner wing by the battery. This coupled to the Charcoal cannister removal lets air flow freely through your intercoolers. You can also move the washer bottle to the same placle on the other side, but there is a bit more plumbing to do shifting the wiper relays and stuff.
Thanks Mark.. Ideally, I would just like to move the exhisting tank.. I suppose it's just a case of extending the plumbing from the rad, and locating the filler neck.
