protoj · 12 hours ago 12 hr
Hi can anyone help please? Just got back from holiday so car been stood for 2 weeks and the battery has gone flat,problem is the remote central locking now wont open the door. The car has been de locked so i cant get in to charge the battery up!!! Any ideas???
