Reaplcing stock fibreglass rear spolier
Hi,
Is the best way of fixing a new fibreglass rear spoiler to bond it, say with Sikaflex?
Vijay
Quite simply, yes :)
One more thing, the boot is bare metal at the moment and I assume it's best to etch prime it first before I stick the spoiler on with Sikaflex?
Vijay
I would prime at a minmum, but as Primer is porous I would be tempted to paint it first before fitting spoiler.
Wot he said!
Would I get away with using single pack aerosol sprays underneath the spoiler? Etch primer then normal primer then a topcoat?
probably a good compromise.
but remember to use plenty of aerosol topcoat.
Them 400ml tins only have 20ml of real paint in them :shock:
:D :D :D
Guys, can I have a step by step on the best way of doing this i.e do I sand between coats and if so what grade? How many coats of each paint would you suggest? And is there a right aerosol paint to use?
The problem I have is my car will be put on a trailer and brought to a paintshop once the last bits (spoiler and headlight panel mainly) are finished hence I need to fit the spoiler before it goes to the paintshop :(
Vijay
or even better, how easy is it to mix up 2 pack paint as there's a compressor there with a spray gun
don't try spraying with 2 pack unless you know what you're doing - lethal stuff!! You need a ventilated mask and proper extraction etc...
can't you just get them to give it a quick spray over the boot, move on to another panel then you can bond it on in between coats??
and I really don't know what I'm doing so maybe give the 2 pack stuff a miss!! lol
Might have to do that but just would have prefered to get it all done before it went in to be sprayed :(
how about going to an accident repair place and asking them to just do the section that will be under the spoiler - doesn't matter how poor the finish is after all... then you can bond the spoiler on and then you/ the body shop that's doing the respray can feather the edges or take it back down to metal?
that's an idea but I'd have to hire a van to get the tailgate to them and pick it up
Yep 2 pack contains Isocyanates!!! .....loosely a chemical brother of cyanide. Dont go there :nono:
If you are stuck as to how to do it all then call me later tonight and I can go thru it in easy steps.
PM me for the number.
Pete :D
Cheers Pete, Got your number already but can't call you tonight cos I'm out. When's another good time to call?
Vijay
