how bad are these readings???
nr.1 -146 psi
nr.2 -145 psi
nr.3 -152 psi
nr.4 -144 psi
nr.5 -149 psi
nr.6 -135 psi
:dance:
so what is happening after 142 ??? starts to eat oil? also what compression it should have with new rings?
:dance:
Don't know!-could be more than rings! :D
Standard should be 186 psi.-ish!
i don't know what you mean by dry or wet test Andy but i.ve warm up the engine i took all the spark plugs out put back the balance bar and put the gauge in every s.plug hole ..press the acceleration on the floor and turn the engine till the gauge stop... i don't know exacly if this is the right way to do it but that how i've done it
:dance:
