Electrical connectors/plugs
Can anyone tell me if/where you can buy the connectors for the wiring looms. I am hoping to make up complete new looms using aircraft grade wire,(Heat proof, much smaller diameter and greater flexibility etc)with the hope of re-routing and moving some of the components. Many thanks Tony. :confused:
You can get some from MJP in the traders section. Do a search under Boldy's name. I think he got a load of connectors from all sorts of cars from a scrapyard.
Ivan
As for the electrical connectors pop down to a scrap yard and rob injector connectors off a variety of cars so the colours match ,
ie Vauxhall are yellow
Ford are Black
Volvo are grey
These all have central alignment ridges , nissan ones have an offset one , you just have to dremel the nissan one off whatever your connecting too and bobs your uncle .
The other advantage is these all have a proper hand spring release system so there much easier to use , cost me a couple of pounds to do all mine
That's what he said.
Ivan
