Manual Conversion Question
With regards the manual conversion, is it possible to use the auto box loom as to my knowledge its gonna be the speed sensor wiring, the start inhibit circuit and rev lights. Rev lights I was gonna wire up through a switch (plus I have other lights to fit to the car). The guys that are (hopefully) gonna carry out the conversion are only gonna do the bare bones of the job, I was gonna finish it off and was hoping the start circuit can be by-passed, speed sensor can be joined to the auto loom, and leave the reverse lights.
Cheers John
yes bud ou can use the auto loom , the speed sensor fits to the manual box no probs , you will need to earth the inhibitor switch tho , its one of the wires on the 6 pin plug behind the driver head light
Fantastic. If it comes to it I will change the loom to the manual when I get the car back. I am guessing its quite straight forward, I will have a look at the wiring diagram later.
Cheers for the reply. John
Cheers for that but the reason for my question is that I was gonna carry out the conversion myself with the parts from my donor car but I am going to give it to a local garage who has 300 experience and has done a conversion as well. Am just trying to keep the work they carry out to a minimum to keep the cost down. If I need to change the loom to the manual one I will so in my time as well as the vacuum pipes as well but thats another issue.
Cheers John
Cheers John
Ok, cool - i posted in there because it covers the wiring you need to move from the manual to the auto.
No worries every reply helps so cheers for that.
John
Its neater to keep the auto loom and it connects behind the headlight, where as switching to the manual loom dosen't. But i do know a couple of changes to make like to the inhibitor.
Hi Chris
What changes are you talking about mate.
Cheers John
