clutch adjustment
how do i adjust the clutch cos its biting right at the bottom on the pedal and its hard to change gear is it done at the pedal or is it an under the car job
simon
Get yer self down and look up where the clutch pedal arm goes up by the firewall, you will see a rod sticking out with a 14mm nut on, loosen the nut and turn the rod with a pair of pliers CLOCKWISE, anti clockwise is to make it bite sooner.
cheers
smithy
thanks but i found the problem there was no fluid left in the resivoir biggrin.gif lol thought it was cable till i looked in the manual
How did looking in the manual tell you what was in the resevoir ? biggrin.gif LOL
