protoj · 3 hours ago 3 hr
hi guys n galls , went through some pics today of A SANTA POD JAP FEST MEET A FEW YEARS AGO and i found a pic of a silver 300zx reg number g25 sck , if its youes gimme a pm and i will send you the pic
