Hicas Light
What is the usual problem if the hicas warning light stays on, could it be anything to do with a car being laid up for 10 months? Does the hicas have to be working in order to get an MOT?
Cheers in advance.
Usually power steering fluid low.
No most mot testers wouldn't even know the car had rear steering !
once the weather gets colder the hicas lights come out to play,
if u top it up it goes away,
nothing to do with mot
would the MOT not have something to say with the light on?? i know over here with the NCT mot's irish cousin that if there something on the car that doesnt work then its gotta be fixed of its a fail that includes anything lit up on the dash thats not supposed to be..
as EDK83 said, take the bulb out. get your mot then find the problem
Or just top up the power steering fluid.
LMAO how true! ;)
LMAO how true! ;)
But what happens when the power steering is topped up and the bloody thing still comes on and off now and then?
And the level has not dropped?
Is it when on the motorway?
You are very good arnt you :D yes tis
:D Aftermarket steering wheel?
Oh i see you been reading my old threads :nelson: :p
Yep got one of those.........but it is correctly positioned
You sure its the correct boss - has a protruding part at the back to turn the wheel position sensor
Yes Andy purchased from luke along with the wheel, it has a peg to locate into the sensor
More than likely a faulty sensor then
