mid pipes.
i have these decat pipes from the zcentre
mid pipes
On their site it states they are for models upto 1992, why is this?
wont they fit on any Zeds later than a 1992? surely the design wouldn't of changed?
Thanks.
I can only presume Luke has put that becuase of Vosa regulations on Catalytic convertors. They will fit later than 92 , but wont be "legal"
mid pipes
Thanks.
hello mate do the to ends at the mid section look as if there offset with each other like the holes dont match up the same, if this is what it looks like then it should bolt strait on ,if they were to put them on strait they wouldn't fit because the cats site side by side the bolts wont go on
Not sure how accurate this is but I read somwhere that mid 92 on (ie S2) had slightly different down pipe/ elbows. Something to do either have or not having a pre-cat on one side.
Yep it will be due to the precats on the post 92 models. Basically an extra cat in the passenger turbo elbow which made it longer....
