Idle control valve
My car idles well at 900 rpm.
A little higher than stock but thats how I had it set and I like it :)
Now I have changed my heater matrix the idle jumps to 1100rpm when the climate control is on.
Not had it on for about a year as had no heater matrix or air con.
Now the only reason I can think of for the idle increase is to power the air con pump.
Well I no longer have an air con pump so I want my idle to stay at 900 with the heater on as that doesnt use loads of power like the air con.
Do I just pull off the yellow plug or will that cause bigger problems?
No you need to take the grey plug of the FICD valve
Nope :)
sweet! i'll do it in the morning
where abouts is it?
I know the idle one with the yellow plug is rear of engine passenger side
On the body of the idle valve - the unit screws into the side of it pointing towards the centre of the car :)
right next to the yellow one then? I think I have read about it somewhere.
Andy you are a star by the way :)
Yup thats the one :)
LOL no worries :)
hmmm, i have the aircon dissconected, i will also do this, may help my infuritaing running prob
Quick solution is to press the 'econ' button when you have the aircon on - this disengages the compressor clutch and turns the valve off.....
yeah never knew what that button does
oh well ill leave it disconnected
