Door lock mech!!!!! help!!!
To All,
I need some help with my drivers side door....This may make a few of you chuckle but I de-handled my door and installed a solenoid.
I got it to work great but for some silly reason I was messing around with the door latch and when I shut the door, although the solenoid works and IS catching, It doesnt open!!
Normally when this happens you can often push a few latches etc and hey presto....it opens but no joy...could it be a faulty door lock mech...?I know it is not the solenoid, I can manually push the door latch...
Help!
regards, G
Oops
Only way i could get into mine with the door shut was to cut a big hole in the doorcard and unclip the soleniod.
Maybe if you know exactly where it is you could get your arm or a welding rod under
taking the seat out might help
cheers Ed,
Fortunately the door card is off and I have access to the mechanism as I just finished installing it today. The prob is although I can push down the handle latch, the door doesn't open for some reason?? I think this happens if the door is looked by the key, however as the handle is no longer there..all the connecting rods have also been taken off!!
I've been tearing my hear out pushing and pulling on the door mechanism latches still no joy..
G
we use these for getting to to cars/vans etc quite effective but your door will be fooked afterwards :rofl: :nelson:
normal.jpg[/img]
