dead/faulty stock boost gauge
For some reason my stock boost gauge has stopped working, it just sits to the far left (as it does when ignition is off) on -7. I have an after market boost gauge which is working fine - shows good vacuum on idle and boost under load. There doesn't appear to be any pipes hanging off that I can see anywhere.
Any ideas? Is the stock gauge electrical or mechanical?
The stock guage is electrical, located at the back of the engine bay on the drivers side, its fed by a vacume pipe from the balance bar iirc and its a black box
If you have an after market one fitted i guess thats why stock not working
No. Both were working fine up until today, the after market one is plumbed in on a t-piece.
I'm guessing that the boost sensor could be at fault, but I have never heard of one them fail before?
Check the hose hasn't popped off the sender - drivers side arch behind the suspension turret, black box similar in size to a box of matches...
Cheers for that Andy, will take a look later on.
