January 4, 200817 yr anyone got any idea how to fit manual boost controller to my 1990 tt i got one valve one tee piece and some pipe but no instructions cheers
January 5, 200817 yr you will need two t pieces and 2 straight connector pieces. ย I did mine its easy, here is a guide on how to connect the hoses it should help although its for an ebc they hose up the same but into a mbc instead of the ebc solenoid. ย http://www.twinturbo.net/net/viewmsg.aspx?forum=general&msg_id=1260622 ย il find a better fitting guide, there is one here somewhere im sure....
January 5, 200817 yr By the way how much more boost are you intending to run? make sure its chipped with a reputable source. you dont wanna go making holes in your pistons :(
January 6, 200817 yr Author cheers for that mate i just wanted to lift the boost to around 14 psi as ive been told 15 is the max on stock turbos
January 6, 200817 yr yeah turbos will be fine but your pistons may cook..... without the right fuel mixture. youve been warned as loads of peeps on here have piston ornaments. im sure il have some soon also.
cheers
