January 2, 200818 yr Fairly straight forward. Unbolt diff(2 large bolts), seperate from Subframe and then knock/gouge/burn out old bushes and out in the new ones. Replacing the rear subframe bushes is however a right PITA job, as you have to drop the entire subframe.
January 2, 200818 yr Author http://www.z1motorsports.com/product_info.php?cPath=6_8&products_id=1581 these are the ones im guna buy. how can you be certain these are buggered? i get a knocking noise from the back of the car when releasing clutch to pull off. what exactly to they aid in doing? are the just mounts for the diff?
January 2, 200818 yr Author http://www.z1motorsports.com/product_info.php?cPath=6_11&products_id=1459 also wanna purchase the nismo transmission mount.. has anyone fitted one of these? did it improve the gearbox feel/movement/vibration etc? ????? thanks
January 2, 200818 yr The diff bushings are just mounts for the diff, to soak up vibration. Your best best would be to jack the car up (or even better on a ramp) in the air and then with the help of a friend see if you can see where the clunk is coming from while one of you accelerates on and of the throttle. The Nismo transmission mount is a better design that the stock one, which is flawed and suffers sagging, it wont improve performance or feel, it will just mean less likelyhood of sagging. However it is firmer so could mean you feel more transmission noise, but I have'nt driven a zed with one that I know has been fitted with.
January 2, 200818 yr Author Hmmm looks like i got some investigating to do... right im guna get it on the ramp 2mow, or jack stands.
January 2, 200818 yr http://www.z1motorsports.com/product_info.php?cPath=6_11&products_id=1459 also wanna purchase the nismo transmission mount.. has anyone fitted one of these? did it improve the gearbox feel/movement/vibration etc? ????? thanks Got one to fit on mine, will try to fit it on Friday, will let you know the results if I get it on the car. Paul
January 4, 200818 yr cool keep me updated. Ok, fitted the new nismo gearbox mount today, left the exhaust in place, that was fine to take the old one out, but a bit fiddly to put the new one back, the old mount was totaly shagged, the new one being higher made it a bit tight, but with a bit of levering and tapping it went in, another pair of hands will make it easier. Started the car and noticed alot of noise being transmitted to the inside of the car, (I think Legrath said this could happen)took it for a test drive very noisey at around 1800-2000 rpm but dies down after that, hoping that it will settle down after a few hundred miles,the vibration that I had seems to have gone at the moment but maybe the noise is masking it. Paul
January 6, 200818 yr it could be the exhaust touching something it wasn't before but I'd also check the engine mounts, if they're no good your gearbox could now be sitting at a funky angle.
January 6, 200818 yr Author Well im getting a knocking noise on and off the throttle, not much vibrartion mind you. like a clunk. im positive its not the exhaust, as its very snatchy in gear especially if at low revs like the cars rocking back and forwards........
January 6, 200818 yr Author Ok, fitted the new nismo gearbox mount today, left the exhaust in place, that was fine to take the old one out, but a bit fiddly to put the new one back, the old mount was totaly shagged, the new one being higher made it a bit tight, but with a bit of levering and tapping it went in, another pair of hands will make it easier. Started the car and noticed alot of noise being transmitted to the inside of the car, (I think Legrath said this could happen)took it for a test drive very noisey at around 1800-2000 rpm but dies down after that, hoping that it will settle down after a few hundred miles,the vibration that I had seems to have gone at the moment but maybe the noise is masking it. Paul but does the gear changing and pulling off and on the throttle feel more tight less movement and play?
January 6, 200818 yr Ok, fitted the new nismo gearbox mount today, left the exhaust in place, that was fine to take the old one out, but a bit fiddly to put the new one back, the old mount was totaly shagged, the new one being higher made it a bit tight, but with a bit of levering and tapping it went in, another pair of hands will make it easier. Started the car and noticed alot of noise being transmitted to the inside of the car, (I think Legrath said this could happen)took it for a test drive very noisey at around 1800-2000 rpm but dies down after that, hoping that it will settle down after a few hundred miles,the vibration that I had seems to have gone at the moment but maybe the noise is masking it. Paul I would'nt of expected the noise difference to be THAT noticable. Check the Exhaust mount that fits onto the back of the gearbox is in properly, if its not, and the exhaust bracket it touching the gearbox or anywhere else on the car body instead that would explain the extra noise.
January 6, 200818 yr I would'nt of expected the noise difference to be THAT noticable. Check the Exhaust mount that fits onto the back of the gearbox is in properly, if its not, and the exhaust bracket it touching the gearbox or anywhere else on the car body instead that would explain the extra noise. Ok, been out looking at the car to day trying to find what was the cause of the extra noise, looked at the exhaust pipe's to see if anything was touching, all was fine. Looked around the engine bay and spotted that one of the domed nuts that hold the balance bar on was touching the strut brace that I had fitted in the summer, so I gave it some extra clearance and all is fine, have not taken it for a test drive yet but it sounds better just on tick over, the extra height of the new mount was enough to make the nut touch the brace,will take it out tomorrow to confirm this was the problem. Thanks to MIKeH and Legrath for their help with this problem. Paul
January 6, 200818 yr Author hmmmm i might have to order one of those mounts? how old was the standard mount miles etc?
January 7, 200818 yr where did you get your nismp mount from mate? See you already got one, Took mine for a test drive tonight and it's much better, vibration has gone but still noisier than the other mounting, (which I was warned about) hoping that over time it will die down a bit, I'll see how it goes might get a standard one if it bugs me too much. This one only cost me £45.00 inc p&p from a nissan dealer in the USA. Paul
January 7, 200818 yr Author Cool, noise doesnt bother me too much. we will see tho. My drivechain needs improving whatever the case.
Whats involved with replacing Rear Differental Bushings on a z32 tt?
